canon IR5075 line
  • Hopper
    • Jul 2008
    • 173
    canon IR5075 line
    I have a IR 5075 with a line. This scan does not do it justice. It is as thin as a hair and is coming from the print engine of the body. I replaced the web and UFR looks fine. Did a stop copy and it IS happening coming out of the drum. I cleaned out the pre-transfer a couple of weeks ago. What makes this weard it has squiggles. Like it is a laser or something. On the left that is a zigzagunder where it has SMB server. The reast of the line look like squiggles almost like a sin wave. Lots of stuff about the lasers going bad.
    Thoughts?IR5075.pdf
  • dan7777
    • Dec 2012
    • 680
    Re: canon IR5075 line
    Thoughts?[ATTACH=CONFIG]34398[/ATTACH]
    Laser or laser slit glass you can remove by charge corona. Have seen wavy lines on laser. You can probably clean the mirrors in the laser.
    • Hopper
      • Jul 2008
      • 173
      Problem solved. Got this info from another tech. Removed developer and there was a pile of toner on a mylar strip over the doctor blade of the developer. Their solution was to clean off the pile and remove the mylar strip.
