C3480 duplex jam
  • repeatcopiers
    • Sep 2008
    • 591
    C3480 duplex jam
    We have a Canon irc3480 in the field (far away) that copies single sided documents fine, but when they do 2 sided, the copy stops right before it feeds back into the duplex assembly and says Jam. It is as though its not getting the signal to reverse. It does not have a finisher. Would like to get this done in one trip, has anyone seen this before? Would it be the reverse roller or reverse sensor? I do not have a Jam Code
  • ernesto
    • Oct 2011
    • 430
    Re: C3480 duplex jam
    Hi, May be the last sensor flag is out of its place....
    • sharptech1
      • Oct 2011
      • 163
      There is a flapper on right door that gets stuck
      • techandtrader
        • Jun 2016
        • 335
        There are a couple of dampers under that flapper that could stick. Make sure you put in the updated feed rollers for this model. There are now TWO. The pick and the feed.
        I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
        • Canuck
          Tech Specialist
          • 1713
          If it doesn't make it to right door(eliminating damper issue) then the actuator assembly has popped out. Very common on these
          • techandtrader
            • Jun 2016
            • 335
            That has not been a common occurrence for me. I can tell you that last week I was given this same symptom by the customer. Could have been humidity caused but the machine also needed updated feed rollers. Changed those and the Chinese fans disappeared.
