IR-6075 Waste Toner error after replacement
  • KM_Copia
    • Sep 2015
    • 5
    Hello,
    I emptied the waste toner and the there is still an error ''waste toner is full''. There is no option as in the IR-7075 in maintenance menue for the waste toner reset, and even if I try to clear the error in service mode, the error is still there. Any of you know how to fix this issue? I didn't found anything in the manual or internet.
    Thank you
  • kstan268
    • Apr 2012
    • 85
    Re: IR-6075 Waste Toner error after replacement
    Originally posted by KM_Copia
    Hello,
    Thank you
    Did you try service mode-counter-misc-WST-TNR clear the counter
    • KM_Copia
      • Sep 2015
      • 5
      It worked! Thank you!!!
      • kstan268
        • Apr 2012
        • 85
        [QUOTE=KM_Copia;536869]It worked! Thank you!!![/
        you are most welcome
        • meldwo
          • Feb 2012
          • 36
          Thanks for this post
