E0001-0150 imagepress 6000
  • Joseph2011
    • Aug 2011
    • 88
    good morning
    I have a problem with a team ImagePRESS out the code E0001-0150 6000
    I've already cleaned fixing units checked everything but when you turn the units for more fasteners are out out the code E0001-0150
    I already gave reset the COM MN DCCON and I disconnected the cables and placed back but get the same codes
    Please your help with this team
    Thank you
  • lilleputte
    • Jan 2013
    • 154
    Re: E0001-0150 imagepress 6000
    How does the thermistor look ?
    Try to replace the thermistor
    • AlexSV
      • Feb 2013
      • 17
      replace the thermistor 100 percent, or clean it
      • Joseph2011
        • Aug 2011
        • 88
        Goodnight
        e0001-0150 error code output from the computer is turned on even with the doors open and fixing units out, and later I disconnected cables and connector cables main unit fixing and I came out the code E750- 2000, but after returning to delete the code and drives out the error keeps coming E0001-0150
