canon 3300
  • sbcxerox
    • May 2016
    • 5
    canon 3300
    Hi,
    i am using 3300 machine ,now the problem if i copie in A4r direction back to back text matter should be cut,kindly give me solution friends
  • kstan268
    • Apr 2012
    • 85
    Re: canon 3300
    Originally posted by sbcxerox
    Hi,
    can show sample print??
    • sbcxerox
      • May 2016
      • 5
      Re: canon 3300
      At present i dont have sample page,but text cut in edge line,some techinician say it should be settings problem in service manual its correct or not
      i dont know how that make it
      kindly tell me that settings
      If i use ADF A4R direction the copie should come, edge text cut in back to back option
      • roho
        • Mar 2009
        • 844
        Re: canon 3300
        A picture is worth a thousands words, it's hard to figure out what you are exactly asking. You say copy, glass or dadf? Too much to guess at without more info.
        • acfife
          • May 2012
          • 63
          Re: canon 3300
          Is your paper loaded A4R in trays too?
          Try using calendar style in 2 sided mode also
