Canon i-SENSYS 3010 Not powering up.
  • DAG COPIERS & COMPUTERS
    • Oct 2010
    • 860
    Hi folks, i have a canon i-SENSYS 3010 which is not powering up. I did some preliminary checks on the main board, fuses intact, major suspect components like fusible resistors are also intact. Its a referral case, initial problem was blown reservoir capacitor due to power surge. capacitor replaced but still not powering up.
    Any help from member with previous/ similar experience is welcome. Thanks in advance.
  • teckat
    • 16083
    Re: Canon i-SENSYS 3010 Not powering up.
    It's all about AC in > AC out to PCB.> DC out>.
    capacitors are more sensitive to temperature and underpowered power sources, have a propensity to expand, causing premature failure.
    capacitor should sit flush to the board, and the cap should be at a near perfect 90-degree angle to the motherboard.
    Something on the Bus Line may be damaged.
      • Oct 2010
      • 860
      Thanks teckat for your input, I will have to do a detailed fault diagnosis of the PCB and see what I can come up with and post it here accordingly.
