image too dark with error code E000020-0190
  • konica7022
    • Nov 2008
    • 132
    [Error Code] image too dark with error code E000020-0190
    canon c5051i
    prints 2 pages max and then gives E000020-0190 code
    shut down and restarts again 2 copies and error
    more over the images and prints are way too dark
    prints and actual photos attached
  • dan7777
    • Dec 2012
    • 680
    Re: image too dark with error code E000020-0190
    Originally posted by konica7022
    canon c5051i
    [ATTACH=CONFIG]34652[/ATTACH][ATTACH=CONFIG]34653[/ATTACH][ATTACH=CONFIG]34654[/ATTACH][ATTACH=CONFIG]34655[/ATTACH]
    E020 0190 05 Title Error in Y Developing Assembly
    Description Error in signal lower limit with ATR sampling detected value
    Remedy 1. Check if the ATR Sensor Connector is disconnected.■
    2. Check short-circuit of the ATR Sensor (TS5) Harness.■
    3. Replace the Developing Assembly.
    • konica7022
      • Nov 2008
      • 132
      thanks for the info, that part is clearly mentioned in the Canon machine
      but what should i do, i check the sensor and contact and examined to dev which apparently seems to be working fine
      but the yellow toner bottle seems to be empty
      Could this error be caused by empty yellow toner
      AND what about the Dark Images?
      • randall
        • Sep 2009
        • 73
        Clear error code:
        Remove empty yellow toner bottle, using flashlight look inside to see if bottle grippers are both open! If not cut coat hanger bend in a hook shape ond reach in to open both grippers. If both already open then
        Put new yellow toner into machine...
        Power off and remove yellow drum and developer unit.
        Check the coupling at the rear side of the developer unit, if it is black it is the old style. It had Dshape that would strip out causing the developer 's mag roller not to rotate. There was an update/quick fix=white one and a pin because the D shaped shaft actually had a hole already in it!!! As a quick fix,MACGYVER, you can cut an arm off a medium sized binder clip and heat it with a lighter and poke it through one of the legs of the black coupling (hint:use the leg on the flat side of the D) Make sure that the "pin" is long enough to reach into the leg on the other side. Its going to take a couple of heatings, trim off excess pin. Reinstall both dev unit and drum. Power on machine and run auto color mismatch and FULL auto gradation. Test print and check CQ/color....Done
        Easier but machine down longer, and more costly, order new dev unit.
        Hope this helps
        Some people may say I have a short temper, but I prefer to call it
        "A swift and assertive reaction to bullshit"
        • konica7022
          • Nov 2008
          • 132
          Originally posted by randall
          Clear error code:
          Hope this helps
          OH MY GOD!!
          Thanks Randall, I called in a tech guy even he could not tell whats the problem
          any way the machine was still under warranty from refurbisher store so i am send it back
          Switch it for Konica Minolta 452/552
