Canon ir adv 7260 Jams from tray 1 Right Deck only
  • tekkie
    • Mar 2011
    • 114
    [Jamming] Canon ir adv 7260 Jams from tray 1 Right Deck only
    I have a Canon ir adv 7260 that jams intermittently from tray 1 right side deck only it is a 0101 jam fails to reach first sensor.
    Happens 3 or 4 times a day regularly sometimes more.I have replaced the paper pick up assembly still does it.I had information from Canon to fit modified paper level sensors with the orange mark on I replaced both of these still doing it.I was also told to check for burrs on tray 1 guide in the deck have done this All other trays are feeding fine including tray 2 left hand deck.Would appreciate any pointers.
  • randall
    • Sep 2009
    • 73
    Re: Canon ir adv 7260 Jams from tray 1 Right Deck only
    Pull out the fixing feed tray, remove the registration assembly. There is a sensor flag on the frame underneath it in the paper path on the right about 4 -6inches from the rear of the tray flag points to the right inside the rail, check flag action. The return is slow, add a wrap to the spring.
    Hope this helps
    Some people may say I have a short temper, but I prefer to call it
    "A swift and assertive reaction to bullshit"
