MF9170 banding
  • madas
    • Aug 2008
    • 313
    MF9170 banding
    Hi guys
    Have any of you seen this (see attachment)
    the tech has changed the drum and the transfer still the same, he adjusted bias to max- and max+ still the same.
    as far as I know all he did prior was remove the paper feed section so removed the front door.
    any idea would be appreciated.
    Cheers
    Les
    I found out it only does it in colour mode not b/w
