The "red" color shift out of it's position horizontally(like 2mm) while color printing, "Correct Print Colour Mismatch" under Adjustment/Maintenance result "Correction fail" after like 1 min, this problem appear suddenly this morning, before that, I did nothing between the last fine printing.
What I had tried:
Replace a new red toner - no luck
Factory reset (service mode: copier -> function -> clear -> all) - no luck
ps: All of my 4 toner is low, of coz , not for red after I replace a new one, will it be the problem? (but the other toner are still workable)
Thanks and welcome for helps
What I had tried:
