I have picked this up from another eng, we think the main control with the built in NIC card was changed but cant be sure, however when you go to get a meter reading the check says Check Counter - Check device configuration and on a print out the meters are blank, any ideas?
Canon ir1133 Check device configuration
Tags: None
Re: Canon ir1133 Check device configuration
Did you export data before change mc?If it ain't broke, don't fix it
A picture is worth a thousand words -
No, the main board/NIC was fitted and data added manually from machine label and scanner calibrated.Comment
