Canon irA8085
  • xcopytech
    • Aug 2006
    • 1794
    [Jamming] Canon irA8085
    Have a canon ir8085 with strange problem.
    Paper stop at PS28 sensor and stay there without any jam or error code.
    Get message that print or copy is susspend.
    Machine can work for day or two without any problem and then again have same issue.
  • mramlawi
    • Jul 2011
    • 838
    Re: Canon irA8085
    Try to separate the finisher and try , did you tried another drawers
    Distinguished road makes you jewel in rough
    • xcopytech
      • Aug 2006
      • 1794
      Re: Canon irA8085
      Tried from all trays.
      Did not try to remove finisher.
      Confusing is that there is no any jam code.
      • onlyinnewfoundland
        • Apr 2013
        • 235
        Re: Canon irA8085
        When you go into service mode and check your jam history, does it log anything?
        If not, try updating firmware to see if it will show you the code if it jams again...
        • xcopytech
          • Aug 2006
          • 1794
          Re: Canon irA8085
          There is no jam or error code.
          Paper just stay under ps28 and there is message "printing" for about 30 sec.
          Then get message sussped.
          And still no message for paper jam.
          DC-con is 34.01 so will try with newer firmware.
          • xcopytech
            • Aug 2006
            • 1794
            Re: Canon irA8085
            What is the latest SW level for ir Advanced 8085?
            • aco.bk
              • Sep 2012
              • 130
              Re: Canon irA8085
              try this
              F1-T01-N11-10143-02.pdf
