Canon ir-adv 8095 delay jam 1011
  • mramlawi
    • Jul 2011
    • 838
    Weird problem that the machine jaming only on 2 sided , jam code 1011 delay on 101 sensor at finisher , weird that the paper didnt come out from the finisher its only stopped on the finisher will try to send apic , i debut in transfer belt looks like the paper is flying before enter the heater on the 2 sided
    Distinguished road makes you jewel in rough
  • teckat
    • 16083
    Re: Canon ir-adv 8095 delay jam 1011
    Is a puncher attached?
    • Canuck
      Tech Specialist
      • 1713
      I have had this on the external finishers. I find that the plastic white idler rolls don't turn. I stretch the springs pushing them down against the grey rubber rollers. I also clean the Oilite bushings and put a drop of 3in1 oil so that the idlers turn freely. There is also a bushing that the shaft goes through to move the plastic roll assembly up and down. Clean it and a drop of 3in1 oil. Mine started acting up at about 2 million copies on machine
      • mramlawi
        • Jul 2011
        • 838
        thats the jam ...
        • teckat
          • 16083
          see attach pdf------1011--1121---1122 Various Models Finisher Countermeasures
          imageRUNNER ADVANCE 8105 / 8095 / 8085
          Staple Finisher-D1 / Booklet Finisher-D1
          Title :
          1011 Jam Code
          Problem :
          The paper stops at section B2 in the finisher as displayed below; and a 1011 jam code is generated. The finisher does have an internal punch installed. The 1011 jam code is defined as a delay to the finisher inlet sensor S101.
          Solution :
          Check sensor S101 in I/O mode , Sorter>P001 Bit 4 for a change of state. It was found that the sensor was not changing state. Upon further investigation, a loose connection was found at J1081. Connector J1081 runs out to the inlet sensor. Seating the connector resolved the issue.
          Connector J1081 is displayed below.
          Also-----------Update the firmware for the finisher controller and saddle controller (if attached) one at a time. Choose the option 'overwrite all' when performing the update. It may be necessary to use Service Support Tool with a crossover cable if the usb procedure fails. The finisher controller firmware is named 'fin-con' and the saddle controller is 'sdl-con'.
          • Canuck
            Tech Specialist
            • 1713
            Your PDF shows the exact area I am talking about. Clean stretch and lube....
            • mramlawi
              • Jul 2011
              • 838
              Thanks tomorrow will clean and lube...
              • mramlawi
                • Jul 2011
                • 838
                Thanks and sorry for being late , i lub and cleaned the area but same problem still jamming , the one thing that i ddint dont it to check the connecter ,ill check it tomrowo hope it works, by the i made update and still jamming.
                • mramlawi
                  • Jul 2011
                  • 838
                  The weird that i tried the finisher on another machine and theres no jam
                  • tinnyjay
                    • Oct 2009
                    • 655
                    I faced this problem before. Just you have to clean white plastic roller shaft, because they lube it with a non appropriate lube.
                    If you try by hand you cant roll'em.
                    "Who loves the roses,must also bear thumbs"
                    • Arcadian
                      • Feb 2010
                      • 218
                      possible it might be the bridge area, clean those rollers they get build up!!
                      warm water on a soft towel and scrub those rollers upper and lower.
                      good luck
                      • mramlawi
                        • Jul 2011
                        • 838
                        good luck
                        I have replaced the bushing and installed the tunning one try it and think it solved
                        • Arcadian
                          • Feb 2010
                          • 218
                          excellent, im working on these alot
                          • Canuck
                            Tech Specialist
                            • 1713
                            Here is the mod to address the issue..10-11 jams.pdf
