Error E00007-0001 on IRA9060PRO
  • Cmp4you
    • Oct 2016
    • 37
    [Error Code] Error E00007-0001 on IRA9060PRO
    Hello dear technicians,
    we are having a problem with our 9060pro from Canon. The machine received a belt fixing 2 weeks ago and now we are getting an Error (E00007-0001). From what I've read it has to do with the fixing unit. I called a technician from Hannover (Germany) and he said it might fix it by doing: COPIER > COUNTER > DRBL-1 > FIX-BLT-U > CLEAR
    COPIER > COUNTER > DRBL-1 > FIX-BLT-L > CLEAR
    But the error is still existing. It would be so good if you could help me/us, because time is running for us and we're losing customers.
    I am glad for every helping answer!
    Lovely Greetings!
  • teckat
    • 16092
    Re: Error E00007-0001 on IRA9060PRO
    E007-0001 error code may be caused by a bent or malformed Front Arm Tension mechanism (FM3-4826-000).
    Inspect the Front Arm Tension mechanism to see if the gears are meshing together for positive drive for the belt. Also that displacement sensors are aligned correctly on the plate.
    • Cmp4you
      • Oct 2016
      • 37
      Thank you for your answer. I opened the printer up and looked through the system to see if something is bent.
      But everything seems to be alright. You got anything else for me to do?
      Greetings!
      • dan7777
        • Dec 2012
        • 680
        Greetings!
        I had one of the E007 codes after replacing the upper and lower belts and never could figure it out. I took a fusing assembly out of a trade in to fix it. Don't remember the exact code. One thing I noticed was the sensors on top of the belt must be so the top sensors are unblocked on that big flag. You can just push the belt back to center to get it to center. I like to replace both the upper and lower units at the same time. They last a year or two. It is easy to break the top sensor arms if you put that top belt upside down. I used to have a bunch of those but they traded them in for the newer models. If all else fails you have to order the base assembly and try the same or new belts. Very expensive fix.
