Does anyone know if the A1 trimmer works on a 7095? Thank you for your input.
A1 Trimmer on an Image Runner 7095
Re: A1 Trimmer on an Image Runner 7095
Comparisson between imageRUNNER series:
Items in RED indicate advantagesFeature imageRUNNER
105+ / 9070 / 85+imageRUNNER
7105 / 7095 / 7095 Printer / 7086Print Speed 105 / 90 / 85-ppm (Letter) 105 / 95 / 86-ppm (Letter) iR Controller Platform 3rd Generation ImagePlatform
Canon custom processor (single)4th Generation ImagePlatform
Dual Canon custom processorsMemory 512MB RAM
20GB Hard Disk1GB RAM
40GB Hard DiskResolution 600 dpi x 600 dpi (Scan)
1,200 x 600 dpi (Interpoloted) (Copy)
2,400 dpi x 600 dpi (Interpolated (Print)600 dpi x 600 dpi (Scan)
1,200 x 600 dpi (Interpolated) (Copy)
1200 x 1200 (UFR II and PS Print)
2,400 dpi x 600 dpi (Interpolated) (PCL Print)Paper Capacity Std. 4,150 Sheets
Max. 7,650 SheetsStd. 4,150 Sheets
Max. 7,650 SheetsMulti-feed Detection Sensors Not available Standard Finishing/Output Options Finisher K1N/K2N, Saddle Finisher-K3N, Paper Folding Unit-C1, Document Inserter-B1, Booklet Trimmer-A1 Finisher-V1, Saddle Finisher-V2, Paper Folding Unit-D1, Document Inserter-C1, Booklet Trimmer-B1, Puncher Unit-V1, High Capacity Stacker-A1, Perfect Binder-A1, Professional Puncher-A1 Saddle Finisher capabilities 3,000-sheet stacking, 100-sheet stapling, 15-sheet Booklets (60 imaged pages), Saddle Stitch Tray capacity 30-sets, Standard 2/3- hole punch. 5,000-sheet stacking, 100-sheet stapling, 20-sheet Booklets (80 imaged pages), Unlimited Saddle Stitch Tray capacity, Optional Puncher Unit-V1 or Professional Puncher-A1 Supported PDLs Canon controller: Canon UFRII, PCL5e/6, PS3 emulation
imagePASS-M3: PCL5e/6, Adobe PS3Canon controller: Canon UFRII, PCL5e/6, PS3 emulation
imagePASS-S1: PCL5e/6, Adobe PS3Mailbox support Standard
8,000 total accumulated pagesStandard
20,000 total accumulated pagesUniversal Send / PDF Enhancement Kit Option / Option Option / Option Web Access Software Option Option Secure Watermark Kit Not available Option Canon MEAP Standard Standard Toner Yield 36,600 Impressions @ 6% (1.65Kg) 47,000 Impressions @ 6% (2Kg) Drum Yield 5,000,000 Impressions 6,000,000 Impressions **Knowledge is time consuming, exhausting and costly for a trained Tech.** -
**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
