E000100-001 code comes up frequently can be reset and copier used, after copier goes into sleep mode and brought out code returns, I had it come up after making a copy a little break then went to make another copy and the code came back. Are the thermistors the most likely cause???
Image Runner 5065
Tags: None
Re: Image Runner 5065
E000100-001 code comes up frequently can be reset and copier used, after copier goes into sleep mode and brought out code returns, I had it come up after making a copy a little break then went to make another copy and the code came back. Are the thermistors the most likely cause???Comment
