codigo en ipf 700 -710 03130031 2F2A
  • Joseph2011
    • Aug 2011
    • 88
    good morning
    Please I need your help with an ipf 700 exits the code 03130031 2F2A I have already reviewed everything I have changed purge unit, ink pipes and where the head goes
    That same code me sle in a ipf 710 where I also changed everything to the main card and nothing
    Any suggestions or directions to solve this problem
    Greetings
  • teckat
    • 16083
    Re: codigo en ipf 700 -710 03130031 2F2A
    Originally posted by Joseph2011
    good morning
    Greetings
    Feed roller HP sensor
    The feed roller HP sensor sets an LF eccentricity correction home position by detecting transitions from black
    (shielded) to white (transmitted), or a reference, in the scale in the code wheel.
    Feed roller encoder sensor
    The feed roller encoder sensor detects the carriage position from slits in the feed roller pulley as it is driven.
    03130031-2F2A = Feed roller HP sensor error
    Check the feed roller encoder and surrounding part. Check to see if paper has not jammed.
    Feed roller sensor not detecting rotation of the feed roller.
    You will find it at the left end of the roller. It may have come dislodged or just gone faulty.
    You will find an encoder strip (curled into a ring shape) and other sensitive parts that can be cleaned carefully.
