Canon ir2016 - bypass working continous
  • savi0r
    • Sep 2010
    • 363
    [Jamming] Canon ir2016 - bypass working continous
    Hi guys. I am having this problem with an canon ir 2016. When you try to copy from bypass, the bypass moves up and down continous. I guess it's a clutch that's causing this problem. Maybe someone can point me the exact one. Thank you.
  • mosey1100
    • Mar 2009
    • 143
    Re: Canon ir2016 - bypass working continous
    Maybe the pickup roller isn't turning after the lifter plate is lifted. You should check if the roller turns freely which it shouldn't. There is no clutch that drives the bypass on this machine only a solenoid that releases the drive for the roller which is driven by the main motor.
    • savi0r
      • Sep 2010
      • 363
      I found the solenoid then. Thank you sir.
