Canon IR3235 poor quality printing.
  • LTTP
    • Oct 2016
    • 83
    Hi, one client is reporting really poor printing quality, attached are some scans hope the issue can be clearly seen.
    They use generic toner refills, and about 3/10 of prinbt jobs have loose toner that can be removed with a finger tip, any advice appreciated
  • teckat
    • 16083
    Re: Canon IR3235 poor quality printing.
    Toner flakes off ===
    using gerneric products
    check fixing units
    • LTTP
      • Oct 2016
      • 83
      yeah thats the first suspect, since the fuser and fixing unit print just fine on another machine.
      • techandtrader
        • Jun 2016
        • 335
        Canon toners are made with fine particles and high quality. Cheap junk toner is more closer to small pieces of finely chopped sand. Its harder to melt sand.
        But do check your fuser settings to make sure they were not adjusted for high humidity. Normally these do a good job of adjusting themselves for humidity.
        I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
        • cscce
          • Jun 2014
          • 156
          My only experience with generic Canon toner was on IRA c5030 copiers. After a while I noticed that the waste containers were filling up much faster with generic than they had with genuine toner even though the print volume was about the same. So a lot of toner was going to waste, negating some of the cost savings.
          We also developed a ghosting problem which disappeared after only after returning to genuine toner and purging the generic stuff out of the machine.
          Also, since generic toner is gritty it will cause parts to wear out faster. Drums are more likely to fail prematurely, for example.
          Maybe the generic stuff is not they bargain they think it is. If they can't go all genuine then they should at least go with genuine black, which isn't usually much more expensive than the generic.
          • LTTP
            • Oct 2016
            • 83
            Thanks ill look into this, just wondering if you are referring to the fixing temperature in service mode level 1? please elaborate.
            Hi, do you remember if your ghosting problems were simi8lar to the ones in the attachment on this post? those are from yesterday tests, we only changed the fixing density and problem was reduced but not solved, it looks like somew toner isnt melting properly causeing that "wiping" effect, we have taken fuser film out of the equation since that same fguse prints just fine on another machine.
            Also we testede with another brand of generic toner (Katun) and problem persists.
            • teckat
              • 16083
              That internal Print shown, is that a copy of it off glass or is it a direct internal print
              if it's a glass copy issue only ----inspect and or replace the Ribbon Cable to the Carriage Unit ----CCD, Cable FM3-7133-000
              if issue is on all prints and copies
              check position of
              Grounding Tab of the Registration Roller.
              also check for any excess grease on the Grounding Tab
              • techandtrader
                • Jun 2016
                • 335
                Do what Teckat Said. This looks more like an electrical- toner popping issue. We have adjusted for this on a HVT Board in the old ir5800, not as drastic as your example but similar. Yes I was referring to the temp settings for the fuser. Option/ Body/ fixing set to O. Temp Con set to 0 ?
                What I would do is vacuum out the developer unit. A few screws on top and the dev cover comes off. Easy and quick task onsite. Move the mag roller around and get all of it out. Then put in Genuine Canon toner. Check Dev Bias setting under ADJUSTMENT for developer unit. Make it door spec in case someone has messed around with that. You can turn up or down the bias and see if you can get the dev unit and toner to cooperate as a temp solution. Change paper to insure no humidity, moisture or quality issue. Generic toners dont work well in these machines!
                • cscce
                  • Jun 2014
                  • 156
                  The ghosting problem I had on the c5030 was a ghost image of the previous page, not the same as what you are seeing.
                  • LTTP
                    • Oct 2016
                    • 83
                    check position of
                    Yes that tab was lifted up not making contact with the reg. roller, print quality went up a lot thank you. and yes all those scans are actual prints, copies look the same or even worse.
                    FixTemp was set at 3 and temp con set to 0, now i have both at 0.
                    What I would do is vacuum out the developer unit. Check Dev Bias setting under ADJUSTMENT for developer unit. Make it door spec in case someone has messed around with that. You can turn up or down the bias and see if you can get the dev unit and toner to cooperate as a temp solution. Change paper to insure no humidity, moisture or quality issue. Generic toners dont work well in these machines!
                    • techandtrader
                      • Jun 2016
                      • 335
                      Your fix temp was -20c so someone adjusted for humidity and curling paper. Double check all the counter measures for that. Better be sure you have a good fuser unit during all of this. Still want to blame toner.
                      • LTTP
                        • Oct 2016
                        • 83
                        • teckat
                          • 16083
                          believe that is a multi layer VARISTOR to discharge static buildup
