IR-3225 adf scans like duplex all the time for 1 sided and scans 4 times for duplex
  • copyhere
    • May 2009
    • 112
    This is an ADF U1 that I just cant figure out what would cause this.
    If anyone has ever seen this I really need some help. This customer is very far away from me.
    I think I will try a different adf on the machine and see what happens.
    Thanks.
  • teckat
    • 16083
    Re: IR-3225 adf scans like duplex all the time for 1 sided and scans 4 times for dupl
    Thanks.
    Perform the following in Service Mode, to have the Feeder scan the original once for single sided copy.
    Service Mode...LEVEL TWO:
    COPIER > OPTION > BODY > SCANSLCT__set to " 0"
    When in level one of service mode , to access level2, press add functions then #2key.
    Check the setting under COPIER>OPTION>BODY>LEVEL 2>SCANSLCT. (*28* *2 COPIER>OPTION>BODY>SCANSLCT.) There are two settings available.
    0: OFF (Determining the scan area by document detection)
    1: ON (Determining scan area by paper size)
    If the setting is "1" the feeder will scan the original twice. Set to "0" for single scanning.
    • copyhere
      • May 2009
      • 112
      Thanks once again Teckat for the help. I will try that.
