Lower fuser bearings locked up. I was able to get out the door by oiling the bearing. Katun has come up withe a lower fuser roller with pressed on bearings Katun pn: 39155.
Canon IR 5075 with E-014 error
Re: Canon IR 5075 with E-014 error
pressed on bearings that help to minimize premature roller failure caused by loose fitting bearings, with Ball Bearings
what is the warranty period on item ??**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
The bias on the pressure roller and the induction heating of the ufr causes the shaft that the pressure roll bearing fits on to deteriorate. Sometimes bearing is fine but flops around on pitted away shaft, sometimes the bearing is seized. Put in a 6000 lfr assembly. FM4-3160 I believeComment
