E00227 in canon ir 2870
  • aakash@24
    • May 2011
    • 41
    facing error code e00227 in canon ir 2870. is power supply faulty.
  • teckat
    • 16083
    Re: E00227 in canon ir 2870
    E227 == reader unit power supply error
    0001 At time of power-on, the 24-V port is off.
    Disconnect and then connect the power supply harness connector.
    Replace the power supply.
    0002 At the start of a job, the 24-V port is off.
    0003 At the end of a job, the 24-V port is off.
    0004 When a load is being driven, the 24-V port is off.
    Disconnect and then connect the power supply harness.
    what is sub-code--xxxx
    did you check all 24v connections
