Ir6000
  • ARUN MISHRA
    • 80
    [Jamming] Ir6000
    Machine right Deck mostly jam with jam code 0107.
    Pickup roller ,feed roller,speration rollers all replace .
    But problem is still there.
    I checked right Deck feeding unit in other machine ,it works fine.
    Someone help me thank in advance.
    sigpicARUN KUMAR MISHRA
  • teckat
    • 16083
    Re: Ir6000
    check supply voltage & connectors from 0107 issue machine to unit & driver pcb
    Right deck pickup motor M11
    J104-
    DC controller PCB
    A5, A6 GND
    Set the meter range to 30 VDC, and connect the meter probes to the
    connectors on the DC controller PCB of the motor in question as
    indicated above.
    Does the voltage change from 24 to 0 V when the Start
    key is pressed?
    if YES: Check the wiring and the motor driver PCB; if normal, replace the
    motor.
    if NO: Replace the DC controller PCB.
    • Raoufselwaness
      Expert
      • Nov 2008
      • 75
      Re: Ir6000
      dear teckat
      I have an error in finisher V1 57a-8001
      how to adjust paper edge area sensor or paper edge stopper shift motor
      • teckat
        • 16083
        Re: Ir6000
        Originally posted by Raoufselwaness
        dear teckat
        • Raoufselwaness
          Expert
          • Nov 2008
          • 75
          Re: Ir6000
          thank you very much for your continuous support
          and for your gift, it solved the error.
          raouf
          • teckat
            • 16083
            Re: Ir6000
            raouf
            Welcome
