Canon ir7200 : light print out at front
  • xtraez
    • Jun 2008
    • 42
    [Misc] Canon ir7200 : light print out at front
    hi all..
    i'm having print out light image. location .. always at the same area as above. action taken:
    * change corona wire = still happen.
    * clean developing assembly = still happen..
    help me please.
    tq
  • Vegas10128
    • Jan 2017
    • 9
    Re: Canon ir7200 : light print out at front
    More than likely, it needs to be something replaced.
    it Could be worn fuser rollers, or a drum roller.
    Im thinking the fuser rollers may be worn into a flat spot. creating that area super light on the paper. Have you checked any of those out yet?
    • ReproKev
      • 273
      Looks like poor transfer. Which wire(s) did you replace? If you replaced the transfer and separation wires, try replacing the whole assembly.
      • xtraez
        • Jun 2008
        • 42
        Fuserroller-oknoproblem..tqvmfortheadvise.
        • xtraez
          • Jun 2008
          • 42
          HTML Code:
          replace again the whole assembly  -- still happen
          Adjust the height the assembly -- vola its fine right now.. still monitoring.
          tqvm for your assist.
