code 010d
  • akm
    • Sep 2012
    • 155
    [Jamming] code 010d
    Dear/Copytechnet,
    please i face a problem with canon ir3045 that makes jam in duplex in the morning jam code 010D
    THANKS
    AKM
  • MunsterTech
    • Sep 2014
    • 381
    Re: code 010d
    hi,
    these are renowned for jamming, especially d/sided. Alot of things can be done to help jamming, the duplex flapper, has black pads that it rests on, these become indented and stick the flapper so it has a delay jam usually in the morning, after its been resting all nite.
    There are also settings for registration, hv-tr, feed adjust etc, I dont have them to hand right now, they can help, but more than likely if the pads havent been modified then that would be the first place i look.
    • gensys
      • Jan 2011
      • 323
      Re: code 010d
      problem has been found to be caused by the duplex/feed sensor PI 17 becoming dirty.
      The Road will be Mastered by >>> the Going...
      • dan7777
        • Dec 2012
        • 680
        Re: code 010d
        Originally posted by akm
        Dear/Copytechnet,
        THANKS
        AKM
        If your first copies jam you have a sticky pad on a sensor flag. That model is famous for them. Pull on the flag and the one that sticks is your problem. I have had that jam on all copies and the best luck I have had is turning the paper to letter R. Your photo showed the sensor on top of that assembly. That flag sometimes needs an extra wrap. Removing damper pads.pdf
