Yes from all other computers it is exactly the same problem.
There are the Windows 10 and 8.1 Pro versions and all with the same issues. An virtual Ubuntu with generic driver has the same print issues with shadow in printing black text.
So, I have today a normal PDF printed. There, too, one can clearly see that toner has been scattered throughout the text. In the plant the scan of it. On a different printer, the PDF is printed completely flawlessly. In the appendix the scan of the printout.
I'm going to talk to a colleague again tomorrow, and I'll try to swap the developer. The exchange works like this:
Install the unit and then use the service menu COPIER> FUNCTION> INSTALL> INISET-4 / K, or do you have to do something different?
I will exchange the developer and then look. The colleague was of the opinion that the laser in the unit is polluted and therefore the disturbances stir. Can the laser unit be safely opened and cleaned or is this really not planned and afterwards is more dust in it than before?
I cleaned the dust protection glass of the laser unit C / K and carried out the function "Correct color distortion automatically". Now everything works again. On the laser protection glass, there was grease, which seemed to lead to a fault in the control.
