I recently had to replace a fixing assembly and drum unit on a canon ir1435 that had a total count of 35,000. Drum unit ok but fixing assembly at 35k ?? I hope this is not going to be an issue.
ir1435 fixing assembly issue
Re: ir1435 fixing assembly issue
Still having that problem with some of them. I do not have access to Canon Technical Support. I have to believe there are
Technical Publications with modification information. Every time the fixing film has moved to the front and tore up. Also the lower roller has ripples on the front side. Is that what you are seeing?Last edited by RHodg57; 05-20-2019, 09:00 PM.Comment
