ERROR CODE E012-0302 ON IPress C700
  • Rachid.Akli
    • Oct 2011
    • 595
    [Error Code] ERROR CODE E012-0302 ON IPress C700
    Hi to all of you,
    It is about an iP C700 with E012-0302. After replacing the cyan drum unit it worked fine for two days and then, when turning the device on in the morning the same code reapeared again . Note that before replacing the C drum, I swaped it with the yellow. The error code changed to E012-0102.
    -The encoders are cleaned and verified, they seem to be Ok.
    -The primary transfer rollers engagement/desengagement system is verified and it seems to be correct to.
    Welcome to all your ideas.
    Sys.ver : 36.01
    Dcon.ver : 37.02
    Thanks a lot.
    "Find a job you love and youโ€™ll never have to work a day in your life." Nagy's father
  • khattab.al.masry
    • 212
    Re: ERROR CODE E012-0302 ON IPress C700
    Hi dears:
    I faced the same issue it self with the same error and sub-code error and also i cleaned the encoder for cyan drum drive and replaced it with the yellow drum drive also the same error then at the end replacing cyan dev. tank with another new the machine going on.
