Hi: I read on this board how to set the drum life on or off to display in the setup area.
I got in there and found the section that has the Dlife-SW switch in it but no matter what I do I can't get the numbers to change.
Will someone please tell me how to change the number to 1 so it will display?
Now before you think bad of me I have tried to touch the numbers to see if the screen will allow change and nothing happens. Also I see a +/- on the bottom assuming that will light up so I can change the numbers but I can't get it to light.
Which number am I supposed to change? The body number the parenthesis number both?
Any help appreciated
