Canon IRCADV 5250 Vibration when copying
  • tech28
    • Jun 2013
    • 434
    Vibrates when copying, replaced fuser and it still vibrates, reminds me of when on a HP 4250/4350 fuser/swing arm are bad and they vibrate and make that humming sound. Bad drive gears? They look good, no worn areas that are visible. Suggestions please! Thanks.
  • sav1973
    • Oct 2009
    • 43
    Re: Canon IRCADV 5250 Vibration when copying
    I know I had success on one machine replace the fixing drive gears. It comes as a unit and I believe you need to get into the back of the machine to remove the whole thing. But you can just take the front plate off and just swap over the gears which is much easier.
    • tech28
      • Jun 2013
      • 434
      Thanks Sav1973, will try that.
      • dan7777
        • Dec 2012
        • 680
        I agree with this but watch for a pin coming out. Place paper under to catch pin. Some are worse than others. I tell people it is normal.
