AdvC2030 can't access service mode
  • repeatcopiers
    • Sep 2008
    • 591
    I have an AdvC2030 in the shop that I can't get into the Service Mode. All the buttons are working but for some reason it won't go into Service Mode. Any ideas? In the back of my mind, I recall some alternate way of holding down some buttons as you turn it on??
  • teckat
    • 16083
    Re: AdvC2030 can't access service mode
    Could be 4&9 setting
    If applies _Also check if Fax Volume control button is stuck
    To go to Service Mode Classic Level 1 follow the steps bellow:
    1) Select Settings/Registration
    2) Press 2 & 8 or 4 & 9 at the same time
    3) Select Settings/Registration
    • repeatcopiers
      • Sep 2008
      • 591
      Wow, it was the volume control button being stuck!! Thanks so much, I would have NEVER figured that out.
      • teckat
        • 16083
        Thumbs up.jpgwelcome
