Wiring Diagram of Hopper Unit Canon IR 3570
  • princepriyu
    • Jul 2025
    Hello friends
    i need wiring diagram of hopper unit for canon IR 3570 / 4570 photocopier
    ONLY all the connections made on the hopper unit itself, (connections to all sensors, motors, etc) not of the dc board
    i require entire circuit / wiring diagram of the wiring harness that is connected to hopper unit and further sensors.
    i have service manual but there is no such diagram
    please if anybody having it please share.
    thanking you
  • Tonersniffer
    • Nov 2012
    • 74
    Re: Wiring Diagram of Hopper Unit Canon IR 3570
    Page 9 of the Appendix of the service manual. Do a search for TS1.
    For your problem, did manually add toner to your empty developer unit? When I empty one, i just grab a bottle of toner pop the cap off and add toner.
    • princepriyu
      FM2-2839-000
      this is the wiring used to connect entire hopper assembly
      i'm in need of each terminals connection
      • Tonersniffer
        • Nov 2012
        • 74
        FM2-2826-000? That the only other wire harness in between DC Controller.
