imagePRESS C1 - E025-0403 error code !
  • netugur
    • Aug 2014
    • 4
    [Error Code] imagePRESS C1 - E025-0403 error code !
    Hi, my problem is; When I open the machine I see error E025-0403. I looked at the topics in the forum. But I could not solve the problem. I saw something like this; When I pull out the cable to the FK2-0575-000 motor, the machine starts to work. It works normally until auto gradation is written and it gives error E078. If the engine is connected to the cable, the machine immediately switches to E025-0403. I checked all the wires in the front. I checked all the motors, cables, sensors in the hopper unit. I checked the cables with the multimeter up to the sockets. I did not find any problems. I made the DC controller clear operation via service mode.
    Please help your friends know. Thank you.
  • wcanonw
    • Aug 2014
    • 404
    Re: imagePRESS C1 - E025-0403 error code !
    hello good morning friend how did you solve that problem, I have an equal problem, check the black hopper motor cables that are going to
    Side-drive PCB and DC controller PCB
    POWER CORD TERMINAL ASSEMBLY.
    DC POWER SUPPLY ASSEMBLY.
    DC CONTROLLER PCB ASSEMBLY.
    MAIN CONTROLLER PCB ASS'Y. and these parts more
      2years no reply to his Q.....
      doubt he did
      or
      if he did he never came back to update.
      might want to start your own new thread.
      • wcanonw
        • Aug 2014
        • 404
        doubt he did
        or
        thanks
        • wcanonw
          • Aug 2014
          • 404
          problem solved....
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5000
            Can you share?
            • wcanonw
              • Aug 2014
              • 404
              • wcanonw
                • Aug 2014
                • 404
                it was changed (buffer decurrer assembly and unit-s1 power supply). The problem persists ERROR E025-0403 and E0015-0001
                • wcanonw
                  • Aug 2014
                  • 404
                  the optional power supply unit-s1 of the DADF-R1 was installed, the machine was turned on, now another error code E021-0001 came out
                  • wcanonw
                    • Aug 2014
                    • 404
                    Rotary motor unit is hardened and the rear driver pcb assembly has burnt components.
                    The change of the rotary motor unit and the rear driver pcb assembly .
                    The Canon imagepress C1 printer is printing normally.
                    problem solved
                    • wcanonw
                      • Aug 2014
                      • 404
                      problem solved
                      attached photo of the components burned in THE REAR DRIVER PCB ASSEMBLY
