ir c3380 duplex jam
  • pontiac
    • 420
    ir c3380 duplex jam
    Copier copies and prints single sided but jams when duplex is used, Jam code A01, copier displays [ rX DOCS WILL BE FORWARED IN ACCORDANCE WITH CONDITION}no error codes . thanks for replys.
  • Rachid.Akli
    • Oct 2011
    • 595
    Re: ir c3380 duplex jam
    Hi,
    The duplex deflectors may stick with the dumpers.
    Rachid.
    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
    • teckat
      • 16083
      Can you disable the 'RX doc. will be forwarded in accordance with conditions' message?
      Answer : 😱
      No.😭
      This is standard messaging, displayed when a 'Forwarding' condition is enabled.
      You will also note that the option to clear the message board, in System Settings, is grayed out.
      Also note that doing an MMI Clear may not clear this message.
      This status message is similar to the 'Transfer Auto' message displayed on a laser class fax when the transfer functon is enabled.
      • pontiac
        • 420
        Thanks a million everyone , ended up replacing Relay DeliveryController PCB. again thanks
