Canon IR8105 E010
  • skibum
    Independent Service Tech
    • 231
    Canon IR8105 E010
    Is the E010 a drive problem? I can not find it in the manual, the manual skipped over E010??? Any advice would be great! Thanks!
  • teckat
    • 16083
    Re: Canon IR8105 E010
    never seen E010 on this series 8000 series checked all manuals
    re check code
    on the ADVANCE 400 / 500 series
    Main Drive assembly/ Main Motor / DC issue
    • skibum
      • 231
      Re: Canon IR8105 E001
      It is now a E000001-0002. Customer at first had the code E001-0010. Is this the thermisters and possibly the thermal switch?
      • teckat
        • 16083
        E001 -0002= Fixing Assembly high temperature error (software detection)-----------don't forget to CLEAR the ERROR in service mode
        1. Check if the cable of the Thermistor is caught. -> Replace
        the Thermistors. -> Replace the Fixing Upper Unit.
        2. IH control error. -> Replace the Fixing Power Supply PCB
        (PCB10), the DC Controller PCB (PCB1), or the Main
        Driver PCB (PCB2).
        Description
        • The Fixing Main Thermistor (THM1) detects 230 degC or higher.
        • The Fixing Sub Thermistor 1 (THM2)/Fixing Sub Thermistor 2 (THM4) detects 230 degC or higher for 2 consecutive
        seconds.
        Also check fuse FU19 shown below on Main Driver pcb
        the chart below shows the voltage of the fuses, connectors / pin location, loads and error / alarm codes.
        Following is a list of error codes this chart associates a fuse with:
        E824, E005, E121, E023, E804, E820, E401, E025, E020, E008, E002, E001, E000
        Following is a list of alarm codes this chart associates a fuse with:
        33-0026, 33-0027, 04-0073
