E748-2012 IRADVANCE 6275
  • jvargas
    • May 2009
    • 44
    [Error Code] E748-2012 IRADVANCE 6275
  • fm100
    • Sep 2013
    • 14
    Re: E748-2012 IRADVANCE 6275
    Hi,
    The following parts at the same time to be fitted - Flash PCB + new MN-CON1 + new HDD.
    Heard of this fault, and when someone did above it was a positive result.
    Good Luck!
    • lilleputte
      • Jan 2013
      • 153
      I think you need a new flash PCB ,
      you can't use another flash PCB from another machine .
      • PCC.TONER
        • Mar 2017
        • 13
        Hi,
        Flash board error.
        Linda
        china spare part, Toner chip, Copier parts, Toner Cartridge - einmay toner
