ImagePress C1 image position LTR paper
  • victoryprinting
    • Sep 2012
    • 53
    [Misc] ImagePress C1 image position LTR paper
    I am wondering if there is an adjustment that can be made when running single sided LTR stock. It appears that it places 2 images on the transfer belt and 2 sheets of LTR are run through in one pass, which certainly speeds the printing of full color on LTR stock. However, the image for the 2nd sheet is consistently 1/16" - 3/32" closer to the feed end of the sheet. So odd numbered sheets are not registered in the same position as the even numbered sheets. I run business cards, and this variation is quite noticeable after they are cut apart.
    The easy workaround to getting each sheet perfectly registered is to run them LTRR format, which is fine - just slower.
    I'm just wondering if there is a way to adjust the position in service mode or something so that all sheets can be more uniformly positioned on the sheet. I am running 80# card stock through the side paper deck, but LTR 20# bond does the same thing, even through a drawer.
