I have a customer that has 2 Canon ImageRunner Advance units that they want to add fax to. I think I found a part number 5992B002, but not sure if that is correct and all I need. I normally work on HP printers and MFP's. Is there any special instructions for installing and configuring fax board? Thanks
Canon ImageRunner Advance 6275 Fax install
Tags: None
Re: Canon ImageRunner Advance 6275 Fax install
The fax is available as a product code and not a part number. That looks like a Canon product code, simply google it to verify, or consult a sales guide that lists the appropriate equipment options for each device. The fax kit includes all mounts and instructions, fairly simple to install, even on site. -
Thanks for the info. So pretty much a hardware install, no software or firmware update needed?Comment
Just hardware, though flashing everything to current firmware isn't a bad idea. A tip from a Canon specialist was to do a NCU clear and all clear in service after installation. Should be no problem, I've retro fitted a few of them in the field as well as fresh set ups.Comment
SEE INSTALL ProcedureAttached Files**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
