Fuser Grease
  • repeatcopiers
    • Sep 2008
    • 591
    Fuser Grease
    Does anyone know where I can get just the grease for the fuser film on the IRAdvC5030?
  • PCC.TONER
    • Mar 2017
    • 13
    Re: Fuser Grease
    Hi,
    As usual, sell fuser film with grease, not only grease
    Linda
    China spare part, Toner chip, Copier parts, Toner Cartridge - einmay toner
    • Scottb
      • Apr 2013
      • 306
      Re: Fuser Grease
      I use dupont Krytox....I forget where I ordered it but it seems like maybe it was from canon years ago. It was expensive, like 50-60 bucks for a 2 oz tube.
      • guitar9199
        • Sep 2016
        • 1100
        Re: Fuser Grease
        Amazon is your friend...
        • techandtrader
          • Jun 2016
          • 330
          Re: Fuser Grease
          Why did you post GPL 207? GPL 205 is what Canon sells or was available for 3570 style fusers. This info is about 10 years old GPL 205 is what I use to help those 3245 films or 3380 films. I have never tried the 207 looks like it can handle more heat but its still not what was once available with a Canon part number. Maybe still is?
          I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
          • teckat
            • 16083
            Re: Fuser Grease
            Genuine Canon FY9-6036-000 (FY9-6026-000) MolyKote Grease
            Canon FY9-6036-000 (FY9-6026-000) MolyKote Grease, Genuine (S0660)
            • afat
              • Sep 2017
              • 11
              Re: Fuser Grease
              How look the grease yaa? And how to find#buy
              • teckat
                • 16083
                Re: Fuser Grease
                • afat
                  • Sep 2017
                  • 11
                  Re: Fuser Grease
                  How many thousand meters can running if use this grease sir?
                  • teckat
                    • 16083
                    Re: Fuser Grease
                    The grease inside the Fixing Film deteriorates due to prolonged use.
                    all depends on volume
                    EXAMPLE for>
                    C5030 Series
                    for Heat-Resisting grease
                    MOLYKOTE G-8022
                    Tool No: FY9-6026
                    Note; Be aware there are different types of Grease for different models >
                    other:
                    Super Lube Grease=Lubrication; e.g., rollers/gears etc.
                    Conducting Grease
                    =Lubrication; e.g., edge of secondary transfer roller, drum heater sliding area,drive areas, friction areas.
                    • wcanonw
                      • Aug 2014
                      • 404
                      Re: Fuser Grease
                      EXAMPLE for>
                      C5030 Series
                      MOLYKOTE G-8022
                      Tool No: FY9-6026
                      other:
                      Conducting Grease
                      hello a question, how much molikote fat has to be put inside the fixing film
                      • teckat
                        • 16083
                        Re: Fuser Grease
                        • wcanonw
                          • Aug 2014
                          • 404
                          Re: Fuser Grease
                          thanks
                          • teckat
                            • 16083
                            Re: Fuser Grease
                            thanks
                            ELVIS.jpgwelcome
