Canon IRC 2620 - ITB slipping
  • ordinaryhandsome
    • Jul 2025
    Hello everyone,
    just registered here and this is my first post thx to fact that I just got IRC 2620n before a week and I love it. Machine was quite used before, it was laying in some closed moist office few a years so now I got it and I want it to get it back to life. I am not a service tehnican, just doing this for fun and full couriosity refurbishment of my LBP5000 gave me a lot of inputs how this machines work so I am giving myself this second shot also lol.
    Canon IRC 2620n - ITB slipping due to a belt cleaning blade supression. How to make it roll nicely?
    After having a nightmare with selection of several (used) drums and toners that guy gave me with this baby (and 751 errors), I finally got 2620n printing nice & clear, but colors were (and still are seriously) displaced. After non-stop auto-gradation failures and stuff, I checked that ITB is slightly slipping but had no idea why. Thx to one of posters here (teckat) in some other thread who wrote that ITB cleaning blade might be a problem if ITB is slipping, I removed that blade and tried to print without it and... colors at the end were finally aligned as it should be. Yeah!
    I cleaned out (that end-plastic) cleaning blade with alcohol but now problem became bigger. Now, ITB is slipping even more than before, sometimes even stops for a moment.
    How to solve this problem? Should ITB assy inside cleaning do a trick or there is some other ways/adjustments to do in ITB cleaning block?
    Ps: Just asking this because I already took ITB assy out and inspected it, grip doesn't look that bad. Just thinking that higher tension inside assy could damage plastic gears and I really like that machine.
    Thx,
    Joseph
    Re: Canon IRC 2620 - ITB slipping
    Take out the cleaning blade and spread some waste toner along it.
    Sent from my SM-G930F using Tapatalk
    • ordinaryhandsome
      Thx skynet, I tried that, it helped somewhat but bad results are still there.
      OK I found service manual for this machine and I will clean ITB assy, guess there is no other way (like blade adjustment or something).
        The ITB is not that hard to take apart and clean the rollers, try cleaning inside the belt too avoid alcohol. Clean the belt with a cloth and maybe something like wd40 on the rollers
        Since you are not a tech the four foam rollers are transfer rollers use a dry cloth on these nothing else
        • Rod...
          • May 2016
          • 11
          Yes, definitely need to clean the inside of the ITB Assy.. I believe the heart of the issue is that large rubber drive roller for the ITB, but while it is apart use canned air and give her a nice dusting off (out doors of course). Pay close attention to the way you take off the belt, I believe Canon used to have a specific orientation of how that thing should be installed. I think there used to be some kind of markings on the inner lip of said belt and it should be on a specific side (front or back). Also a little wd40 on the big rubber drive roller ONLY.. Good luck.
