Hi Folks,
I'm working on IR 3245 with error e-540-8003, after researching, I'm thinkin I may need to replace the wire harness, for lower tray(as this is the 2 tray model), after my first attempt, to get access to x3 connectors on the bin, I will have to remove upper tray, and lower tray. Does anyone have any directions, to help me with procedure..? I'm also not sure if there's any alignment I need to know about when re-installing the bins....any help greatly appreciated...!
Thanks,
Jaime,
Indep. Copier Svc.
Thanks,
Jaime,
Indep. Copier Svc.
