Canon IR ADV 4235 i
  • PinevskiS
    • Jul 2009
    • 284
    [Jamming] Canon IR ADV 4235 i
    Hi,
    I have a problem with paper station unit on Tray 2,
    Problem is lift, dont come in correct positions. When close tray lift go up but after 5-6 millimetar stop .If have slightly paper in tray when make copy feed roller cant move paper,if I put full paper in tray then feed can take a paper and move .I change feed station unit and tray 2 (with new) and the same problem.
    Any solutions.
    B.R.
  • rudysemira
    • Oct 2016
    • 108
    Re: Canon IR ADV 4235 i
    Originally posted by PinevskiS
    Hi,
    Any solutions.
    B.R.
    did you try to swap the pick-up assy from tray 1 to tray 2? this is first step if you are not sure which part having problem.....if you done it before and same problem check the machine if in a balance position..good luck
