Canon ir 2870
  • aakash@24
    • May 2011
    • 41
    [Jamming] Canon ir 2870
    While duplex printing and copying when the paper moves back to duplex section machine is showing printing in status bar .
    Machine keeps on showing printing and there is no jamcode but machine is in processing.
    Changed IP board,DC cntlr,fuser,powersupply but the problem persists.issue only while duplexing
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Canon ir 2870
    Test duplex sensors in service mode.(sensor test)
    • aakash@24
      • May 2011
      • 41
      Re: Canon ir 2870
      i have replaced same with another working one
      • ernesto
        • Oct 2011
        • 430
        Re: Canon ir 2870
        I think it is because of the toner bottle is low..... I don t know the reason.....
        if you replace the bottle toner it will be ok, or you can put A4R mode and it will be ok without replacing the toner bottle.
        All the best
        • jitenderrawat1
          • Sep 2017
          • 5
          Re: Canon ir 2870
          All the best
          If problem in duplexing please chacked and replace duplex cloutch or motor.
          Sent from my CPH1701 using Tapatalk
          • kstan268
            • Apr 2012
            • 85
            Re: Canon ir 2870
            I had faced two machine with this problem..change duplex clutch solve the problem
