Jamming iRC5235
  • Will1
    • Mar 2013
    • 17
    [Jamming] Jamming iRC5235
    Good day
    I need some advise on a problem we are facing with an iRC5235?
    We are experiencing a jam in the inner finisher. The jam code is 1400, indicating the door switch. We have replaced the door switch but to no avail. We have also change paper sensors and upper and lower home position sensors.
    Have you encountered such a problem before and if so do you have any advice on the possible solution?
    Kind Regards
    William Major
  • duwaynebrooks
    • Aug 2015
    • 43
    Re: Jamming iRC5235
    Originally posted by Will1
    Good day
    Kind Regards
    William Major
    Hi there,
    I have not had this problem but would suggest you recheck the plugs to ensure you have not missed one out on the right hand side of the board thats hidden.
    Other than that I would change the board.
    Hope that helps.
    • skibum
      Independent Service Tech
      • 234
      I had this type off jam on a ir3045 which plagued me for a bit. Check your connection to the door switch. Try pushing on cover that you suspect is the cover/door switch with the error while it is printing. I had to adjust the mechanical connection with the door interlock.
      Good luck!
      • dan7777
        • Dec 2012
        • 680
        Re: Jamming iRC5235
        Good day
        Kind Regards
        William Major
        I looked at the canon website and two posts said to check the upper tray if you have two trays (safety sw on top). You could remove it to check it if it happens a lot. Another post suggested a circuit board if it is at power on.
        • Canuck
          Tech Specialist
          • 1713
          Re: Jamming iRC5235
          Jam constantly or intermittent?
          • Will1
            • Mar 2013
            • 17
            Re: Jamming iRC5235
            Afternoon
            Thanks for all your input. this jam is constant. I will try all options and revert back with my findings.
            Regards
            Will
            • cscce
              • Jun 2014
              • 156
              Re: Jamming iRC5235
              I once had the upper tray issue mentioned above. I used a screwdriver to press down on the switch and the machine was able to re-position the upper tray.
              I also had a problem with a machine in which the photo sensor for the main door failed (the one that covers the ITB and developing unit). That also gave a door open error. Super easy to replace that photo sensor so be sure to check it.
              • Canuck
                Tech Specialist
                • 1713
                Re: Jamming iRC5235
                Do you have proper voltage at the door switch? This is the first step. I'm not near manual...could be 24v is missing. Power supply on machine...maybe accessories PS. Verify the power to the switch before you do anything else
                • petermays
                  • Mar 2017
                  • 91
                  Re: Jamming iRC5235
                  hi does mc have a inner finisher A1?
                  with finisher front door interlock switch closed 24Vdc is measured on CN97..top tray moved up abit to much opening safty switch if u manually lower tray should rest jam code.
