canon irc3080 colours are out of alignment
  • eng_usama
    • 115
    Please help me colours are out of alignment after make all ram clear ?
    It was as working perfect but after all ram clear it make color out of alignment any suggestions
  • rudysemira
    • Oct 2016
    • 108
    Re: canon irc3080 colours are out of alignment
    input again the laser code from the laser unit......
    • eng_usama
      • 115
      How and where to find ?
      • teckat
        • 16083
        __________
        On a sub-scan issue---
        Clean the patch sensors and perform an auto color correction mismatch should resolve the issue.
        To perform an auto color correction mismatch, Enter Additional Functions Adjustments and Cleaning. On page three select auto color mismatch correction.
        If Auto color correction mismatch is not an option, be sure to update the firmware to the latest version. To clean the patch sensors manually actuate the solenoid to open the shutters and wipe the sensors with a dry lint free
        cloth.
        ?? Is issue in Sub Scan( paper feed ) or Main Scanor( operator side to non-operator side ) or both directions ?
        Try Removing the noise dampening pad for the Registration sensor flag and then perform a Reg-Clear, ( go into LEVEL 2> COPIER> FUNCTION> CLEAR> REG, then a Quick Adjust and then adjust the IMG-REG may correct the issue.
        • eng_usama
          • 115
          Thanks going to try all this and till you what happened
          • petermays
            • Mar 2017
            • 91
            hi.open your front door laser settings is there.go to service mode laser.put in all settings for each colour.turn mc off and on.do auto grad then mismatch...just make sure patch sensors are clean.
