jam 1101 irA c5560i with inner finisher h1
  • jmaister
    certified scrub
    • Aug 2010
    • 755
    kinda stumped...
    The paddle unit intermittently drops when its not suppose to(single and duplex). There seems to be a one way cam its attached to. Anyone ran into this? I searched, results were not related to H1.
    Idling colour developers are not healthy developers.
  • bret@cos.flag.org
    • Jun 2020
    • 99
    Re: jam 1101 irA c5560i with inner finisher h1
    I know it's four years later, but I got a report from a user that they're having this same issue on an IR ADV 5560 with an inner finisher H1 machine i service. The paddle drops when it's not supposed to. I'm going to check it out hopefully in the next day or two. Do you recall if there was a resolution to this paddle issue on the inner finisher H1?
    Thanks,
    Bret
    • giogi
      Engineer senior
      • Jan 2016
      • 181
      Change Service mode Level 2 > SORTER > OPTION > FIN-SP1 > Bit 1, Change from 0 to 1. Example 00000010.
      removing excess grease from Paddle Cam area.
      If 1101 jams still occur after these actions, change the Paddle Drive Assembly.
      If the Paddle Drive Assembly does not resolve the 1101 jams then change the Processing Tray Assembly.
      "Knowledge is a source, but unfortunately ignorance is a sea."
      • bret@cos.flag.org
        • Jun 2020
        • 99
        Thanks Giogi,
        I looked up this option (SORTER > OPTION > FIN-SP1) in the service manual and it is very non-descriptive. It just says it is a finisher special setting.
        I could try this, but I would like to know some more about this option before I change it, if possible. Are you able to provide any more information on this setting that you may have?
        Thanks again.
        Bret
        • giogi
          Engineer senior
          • Jan 2016
          • 181
          sorry I do not know the specificationsMy info is a European KB
          Anyway, try it quietly.
          reboot the device and test it.
          if you don't solve it, set the parameter back to 0.
          • bret@cos.flag.org
            • Jun 2020
            • 99
            Ok thanks very much. I will try this as soon as I can. Might not be soon because I don't get to this machine often.
