Canon IRA5035i not coming out of energy saver mode when printed to
  • Lasersupplies
    • Jul 2011
    • 221
    I have a canon 5035i and when it goes into energy saver mode i can no longer print or ping to the device. I know this feature can be switched off but its good to have as the company needs to save on energy. Is there any settings preventing this from coming out of sleep mode?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: Canon IRA5035i not coming out of energy saver mode when printed to
    Can be a problem on controller.
    First try with reseat all connectors on controller and power supply.(maybe swap with other machine)
    Re-seat memory.
    Install last firmware.
    Try with energy save mode timer. Check if it works normally
    • THUK
      • Jul 2008
      • 195
      Re-seat memory.
      Hi
      Change sleep mode from low to high.
      • wassem
        • Aug 2012
        • 166
        this problem may be related to the customer network
        you may check first by connecting the machine connected directly with a pc
