Finisher V1 jamming on IR7105
  • skibum
    Independent Service Tech
    • 231
    The jam code is 100E when it jams. The rear belt inside swing guide area is getting wrapped around drive roller mechanism (FB5-9103-000 ribbed belt). Has anyone had to replace the belts because it is causing jams? It is happening every few hundred to maybe 1500 page intervals approximately.
    Please help! Thanks.
  • tinnyjay
    • Oct 2009
    • 663
    Re: Finisher V1 jamming on IR7105
    There are two belts like that. Sometimes one gets out of its place(mostly the one in the door's side) and you have to put it again in its place. See the other one where its placed and fix the other. I know how to do, but cant help further.
    Hope you do it!
    "Who loves the roses,must also bear thumbs"
