Error code
  • sniper2g8
    • Jan 2013
    • 117
    [Misc] Error code
    please my IR ADVANCE 5051C is giving me this Error code E000020-0191
    After printing one page
    • 16083
    Re: Error code
    E020 with a sub code of 191 indicates an error with the yellow developing assembly.
    Can u turn the yellow dev unit by hand ?
    • wassem
      • Aug 2012
      • 166
      Re: Error code
      i think you need to change the yellow developing tank
      • IndoCE
        • Nov 2014
        • 14
        Re: Error code
        When used after market toner (black ) error 020-491 generated ... I supply ( manual ) genue toner to Dev unit n problem clear
        • sniper2g8
          • Jan 2013
          • 117
          Re: Error code
          I change the developer and it work for some time and return the same error again....
          The Printouts shows yellow toner on the sheet as on the attached page
          • izian
            • Dec 2015
            • 13
            Re: Error code
            Hi you just need to change the yellow drum unit.
            good luck.
