Hot Fixing Drive Motor
  • V-P
    • Apr 2011
    • 679
    [Misc] Hot Fixing Drive Motor
    Hi Fellas,
    I had a E014-0001 today on a iRADV 8295 machine.
    The fixing Drive Motor (M3 I believe) was really hot.
    So I dismantled the fixing unit and replaced both fixing roller and pressure roller with new bushing and bearing and everything.
    Replaced the Cleaning web - replaced main thermistor (FK2-7692) and the 2 sub thermistors.
    Put everything back into the machine. Everything is fine, machine runs fine, NIP Check was perfect.
    I did replace the Toner Filter and the Ozone Filter (the one in the back of machine).
    I thought maybe airflow is not where it is supposed to be...
    The problem is that the motor is still HOT.
    How about that ?
  • teckat
    • 16083
    Re: Hot Fixing Drive Motor
    Originally posted by V-P
    Hi Fellas,
    How about that ?
    [ATTACH=CONFIG]36528[/ATTACH]
    probably pushing too much current through it
    how much constant volume are u pushing ?
    have u checked outlet for proper neutral>to ground ??
    should be in the low millivolt to zero range.
    • V-P
      • Apr 2011
      • 679
      No I didn't make any measurements. Next time I will.
      This machine is new arrival and it replaces an older model (running on the same physical outlets)
      Old building though.
      Funny thing is that the motor is hot even when is not running copies
      • tinnyjay
        • Oct 2009
        • 663
        Hi Fellas,
        How about that ?
        You have to check its temperature when its idle, because when copier its working in a closed and warm place, its so normal fuser motor gets hot. Remove cover where lever fuser/transfer unit its placed and check for the cooler if its stuck somewehere or maybe its not working. If everything is ok down there, check some plastic tubes closed to fuser unit. They are used to remove the heat from motor and outside fuser.
        For me, nothing to worry!
        "Who loves the roses,must also bear thumbs"
        • Rachid.Akli
          • Oct 2011
          • 595
          Hi,
          Have you tried to replace the fixing motor?
          Rachid
          "Find a job you love and you’ll never have to work a day in your life." Nagy's father
          • teckat
            • 16083
            turn off printer/ unplug/ wait 15/20 min.--- then check if motor is hot
            u should
            also check the Relay pcb
            • V-P
              • Apr 2011
              • 679
              Yes it has heat even after 15 min.
              I checked the null / ground / phase. Everything is fine.
              • teckat
                • 16083
                motor stays hot with motor & printer both unplugged
                now that seems impossible without any voltage being supplied to unit
                FK2-7670-000----M3
                have u replaced
                • Geo
                  • 662
                  Silly question , have you compared this machine to others in the field....a hot motor may be the norm...
                  • V-P
                    • Apr 2011
                    • 679
                    To Teckat : When I said it has some heat - I meant cooler than its "hot state" - but still hot.
                    To Geo: That motor particularly (being close to fixing unit) will get some of the fixing heat, but I am talking "you cannot touch it for more than 5 sec - kinda heat"
                    I will order another motor and probably the relay board aswell.
                    Thnx!
                    • teckat
                      • 16083
                      Thnx!
                      causes no jams or errors
                      no smoke conditions
                      Macgyver.jpgcall MacGyver
                      • mramlawi
                        • Jul 2011
                        • 838
                        Hi try to clean the fans also if the machine is set closer to the wall try to relocate it far a little from the wall
                        Distinguished road makes you jewel in rough
                        • teckat
                          • 16083
                          point to note:
                          Fans do not "kool" off 24v dc stepping motors
                          • spectraindo
                            • May 2008
                            • 313
                            Check the Heat Discharge Fan FM3 and the Filters.
                            • teckat
                              • 16083
                              E014 -0001 = Fixing Motor error
                              Lock error of the Fixing Motor (M3).
                              Remedy
                              1. Check the gear of the Fixing Drive Unit. -> Replace the
                              gear.
                              2. Replace the Fixing Motor (M3).
                              3. Check the connection drawer between the Fixing Assembly
                              and the host machine.
                              4. Replace the Main Driver PCB (PCB2).
